I've been tracking some issues with my '07 with a 48re. Hopefully the usual experts will poke their heads in here and chime in.
Basics
Issues/Complaints
I would like to get to the bottom of this issue - determine what the issue is and is this something I should tackle myself or take to someone. I'm willing to tear into it as I've done a lot of work on this myself (injectors, installed a newer and shorter lift, AC repair) but transmissions are something I've never touched.
Basics
- Bought in '13 and PO stated the transmission was a Suncoast. Visually it is the original case so if anything the PO upgraded internals. TC is gray, not orange like some however I’ve seen sites that sell SunCoast TC’s that look identical to mine so I’m not sure if this is an old model or newer. I have a picture if it'll help
- DNJ governor pressure solenoid
- Believe it has a shift kit/modified valve body based on firm shifts
- Front and rear bands adjusted. Lots of adjustment left
- Fluid and filter changed a couple thousand miles ago. My sense of smell is broken but I was told the fluid smelled burnt before changing
- A little bit of material on the magnet, about a 1/4" thick. Rest of the bottom of the pan was pretty clean
Issues/Complaints
- 2-3 / 3-2 clunk. Most notable when the engine/trans warms up. All u-joints appear original but are tight from front to back
- When TC locks at 52 mph the engine seems to bog down - noticeable drop in RPM (don’t have the exact amount but will get that info). I want to say it feels like it slips based on the lack of horsepower it has right after it shifts but not knowing how a truck should shift I may be off on this. Under more throttle it locks up at 60-62 and it doesn’t dog down and sounds more normal
- Sometimes the shift from OD to lock is short when on the throttle. Ex: Climbing a grade in the mountains and it'll go, from a dead stop, 1, 2, 3, OD then quickly into lockup
- Trans runs 190-196 degrees on hot days. Hot as in >=96 degrees and AC on. This occurs once I get off the freeway and hit 3-4 lights before reaching my destination. Understood increased temps in stop and go traffic are the norm but 190+ measured from the in-pan sensor seems excessive. All cooling components on front of truck were inspected months ago when radiator was replaced
- Sometimes TC locks up in 3rd under light acceleration and deceleration. Usually the pattern is 1, 2, 3-lock, 3, Lock where the last two are really quick and unnatural and the bogging issue mentioned above occurs
- P1740 code shows up sometimes. All I’ve ever found from day one on this is “it’s normal for an aftermarket TC”. With all of the problems I have I question if that is true in my scenario
