Yikes!!!
Dash Cam
xps ribs
You have seen someone before that you can just tell they shouldn't be doing the job they are doing? Well... At a truck stop on I-55 in Illinois today I saw one of those people. Parked my dually pickup and 5th wheel camper beside another dually pickup pulling a 5th wheel camper. The guy delivers new camping trailers to dealers which is what I also do but for a different company. Went in the building to do my business and came back out to see he had pulled his truck out of the spot where it was parked and had stopped while making a big u-turn to exit the parking lot. As I finished up my logbook and began to make a sandwich I noticed that he was out of the truck and doing something to the 5th wheel hitch. He appeared to be in his '70's and my observation was that this guy didn't seem to be very well suited for this job, as in he didn't know what he was doing. He then walked back to the cab of his truck then back to the hitch again. The next thing I noticed was that the truck was moving - BUT HE WAS NOT IN IT!!! I could see him start running toward the still open door of the truck to try and stop it. He fell on the asphalt, got up and ran again to try and stop the runaway truck and 5th wheel trailer. Fortunately there were no vehicles parked where his truck was headed. As the front tires went up over the curb and onto the grass the truck turned slightly to the right which allowed the truck to barely miss a parking light pole with a huge concrete base. Finally the truck and trailer stopped and he got in it. I was far enough away when this took place that I could not have caught the truck, it was actually moving pretty quickly considering no one was pushing on the accelerator (it WAS a Dodge Cummins :). I went over to make sure he was ok. He showed me the back of his hand where he had fallen on the asphalt, there was a 3 inch patch of leathered skin that was missing, not much blood considering. Other than that he was ok. I noted that the dually fender on the pickup had scraped the concrete post, nothing horrible, but this was a very new truck. The front lower side of the brand new 5th wheel trailer had also scraped the concrete which meant that he would have to retrace his steps and take the trailer back to the factory to be repaired. His comment was "Well, that's probably it for me!" Meaning that he would be let go from his job. The dually fender on the opposite side of the truck had already been damaged from a previous incident, so I surmise that his prognostication was correct, he would be let go. While I felt bad for him I also believe he really had no business doing that job. God gives us all talents and abilities, and delivering campers is not for that fellow.
How did this incident happen? When he made the big u-turn the breakaway cable for the trailer became caught under the 5th wheel hitch leg and pulled the pin on the breakaway system which applied full braking power to the trailer brakes which brought the truck and trailer to an immediate standstill. He got out of the cab to find out what had happened, saw the cable and got it out from under the hitch leg, then put the pin back in the breakaway switch which released the trailer brakes. That is when the truck began moving because he had left the transmission in DRIVE when he got out of the truck. Just glad no one else or their stuff got hurt.
Godspeed,
Trent
Great story. We went to Indiana the past spring and saw a lot, as in 10 to 30 a day, of contact haulers moving trailers west. My sense was most of them were the CTD.
Hope all is well with that gentleman. My very first and last professional RV haul of a 5ver back in 08, had the trailer brakes engage from a defective trailer plug from the trailer side. When I went to leave the pumps on the auto side of a Flying J truck stop, the brakes would lock up every time I touched my brakes. It jerked so hard I thought it was going to hit my tool box on the bed when turning. It turned out to be the brake light pin melted/shorted to the brake pin on the trailer side of the plug. Because it was night time, I had to have my lights on so a Semi wouldn't hit me, so I couldn't unplug it. I limped it over to a parking spot where I found the problem and had to finish trip without trailer brakes. If I had been 70 years old, I wonder what would of happened if I had no RVing experience prior to the job. That seems to be what was wrong with this gentleman, a seasoned RVer would have known the possible issue of the cable catching on things. I liken it to making sure to look up the throat of the 5th wheel hitch once coupled to make sure it was latched properly. Ever see a trucker with a trailer barely hanging on the back of the tractor, 99. 9% of the time it's because they didn't make sure the 5th wheel had latched properly.
BTW, the 5ver I pulled, got to its destination in perfect shape, except for the trailer plug and factory connections at the axles.
TOO bad he didn't simply yank out the pin and set the trailer brakes again - but, things often happen quicker than we can react...
(I'm 76, and can relate!) :-laf
