HeavyHauler said:Awesome Peter! That is next on my list! I think I'm stretching the limits of the 13" OFE right now - or I will be soon anyway.
I would assume that this version wouldn't be as hard on the transmission too, right? Any differences in what kind of power they will hold?
JCleary said:I think all dual disc clutches are hard on the transmission. They don't have any damper springs, so the engine's spikes are delivered straight to the input shaft. Peter told me to change the oil often with a dd, like every 15k. There is also additonal rotating mass that the synchros have to speed up/slow down every shift.
Nobody can give me an answer on how much wear/tear it adds over a single disc.
HeavyHauler said:I realize this, but I assumed that with this being a "street" version, it would not be as rough on transmission components as an all-out pulling clutch. I'm not an engineer and don't know the science behind these things - I'm just using common sense here. If they weren't a more "friendly" clutch as far as component wear, then why would they even bother producing them? The current DD is not problem at all to operate in my opinion - even those with the heavier plate loads.
Got Smoke? said:Hans he was correct in saying that these DD's will still add a good deal of stress to the transmission because they do not have sprung hubs to absorb the shock. From my minimal knowledge of DD clutches I would say these will engage easier than a "Pulling DD" because of the solid continuous material around the disk. Anything clutch disk that has there material in "puck" form around the disk tends to be a little grabby.![]()
Got Smoke? said:If you still want to shift fast I would suggest going to a 13" FE before a DD. Even though these new clutches will be more streetable than the "pulling type DD" they still will shift a little slower. I miss being able to flat out SQUASH opponents in red light to red light battles, but I don't worry about my clutch when hooking to a sled anymore.![]()
rubberneck said:Peter, which pressure plate will provide approximately stock pedal pressure? thanks phil
