You Might be a Rice Boy If ........
Toyota 4 runner.
For you aviation history buffs
You have more exhaust decibels than your engine has horsepower.
You have aftermarket FRONT wheels for racing but stock rear wheels.
Your engine makes twice as much horsepower as torque.
You ever painted your wheels to match the same color of your car.
You put your automatic car in neutral at every stoplight in order to roll it back and try to fool other people into thinking you have a manual transmission
DuPont gave up trying to figure out the shade you were asking for.
Your mod list includes stereo equipment, shifter handle, MOMO steering wheel, PIA driving lights, exhaust tip, but no REAL engine parts.
A chameleon lizard undergoes fewer shade changes than your custom paint scheme.
Your rims and tires are so large, that you have to install the tire / wheel from underneath the car because it simply won't fit in the wheel well going in from the side.
The dealer laughs when you bring your car back in for service under warranty, and you've only had it 6 months...
Your tires / rims stick out from the lip of your car by more than 1".
Your paint job is from the WRONG end of the color spectrum.
You installed spacers on your STOCK wheels and tires to get them to stick out past the fender.
You see cars like yours in a Shriner's Parade for Children and clowns are driving them.
You bring an empty Maxwell House coffee can with you to compare size when you shop for an aftermarket exhaust system.
Your Eclipse GS-T hardtop has a "SPYDER" emblem on the rear...
Your sum knowledge of suspension is: "the more negative camber, the better the handling. "
You push your car through the staging lanes. That way, maybe
you can break into the 16s by keeping the motor cool between runs.
You add a super tall rear wing, and a hundred pounds of aftermarket ground effects, neon and stereo yet you gut the interior and yank out the rear seat for weight savings.
Your rear wing AND your rear window have a third mount brake light...
The back lighting in the gauges in your A-pillar gauge pod work long before the actual gauges are hooked up.
You cut 4 coil springs and scrape the chassis on the ground. Sparks are cool when you corner at normal traffic speeds!
You have to find a way to drive AROUND speed bumps in a parking lot.
You install clear corner and brake lights.
You install colored bulbs in your aftermarket clear lenses.
You ever put neon on the bottom of your car, and then busted it on the first speed bump you went over.
You painted the UNDERBODY of your car to match
If your rear spoiler is taller then you are.
if you can fit fist **** your exhaust tip
You have more stereo WATTS than engine TORQUE!
If your tailpipe extension is the most expensive mod you’ve done to your engine yet.
Your tailpipe extension fell off during a quarter mile race and you went three tenths of a second faster due to weight savings.
EVERY car in your class has a turbo pushing double digits worth of boost.
You spent $5,000 on the engine and you can not out run a stock Camaro, Firebird, or Mustang
You want the 'wastegate' sound, but don't want to install a turbocharger system.
You think Nitrous Oxide on your Hyundai Sonata puts you in the same performance league as the Chevy Corvette.
The automatic version of your car runs 2 seconds slower in the 1/4mile.
If the 1970 Plymouth Daytona Superbird has a smaller spoiler than your car does.
You think the Del Sol is a sports car...
A torque converter does NOTHING for your car.
You think a deep farty noise = the sound of high performance
If you think that horsepower is far more important than torque
If you have ever claimed that switching to a cone filter has given you more than 5 HP.
If you have ever considered installing more than one set of fog / driving lights.
If you claim that the aftermarket cold air intake system you just installed doubled your horsepower or took 2 or more seconds off of your E/T.
Your baseball cap is always on backwards when you drive (the first sign of mental retardation, wearing your clothes backwards... BE).
You spent all night on the Internet trying to find a company that makes a turbocharger system for your Hyundai...
If you removed your side view mirrors and put them at the TOP of the door / window frame.
If you think the Fugees are 'speed' music.
MOMO is 'absolutely required' to go fast.
Your four cylinder has a dual exhaust system installed.
Your four cylinder has four exhaust pipes ("Hey, one for each cylinder!")
The color of your interior upholstery hurts the cones and rods in other people's eyes.
If you cannot drive your car in snow as the ground effects create a plow effect.
If you have installed driving lights to compensate for headlight blackouts / tape.
If you think that 180 horsepower and 185 lb/ft of torque are impressive for a ‘mildly’ modified engine.
If you have stickers on your car for parts that you could not point out if asked where those parts are installed.
You think pushrods are a bad thing…
Your car has more decals than you do the quarter in seconds.
Every Honda you EVER owned, all the way back to your 1978 Accord was either a V-Tec or a TYPE-R.
You took your rear seat out and gutted your interior for weight savings but you installed 400 pounds of electronics, neon, DVD, Sony, etc.
If you gutted the interior to save weight on a car that you will never take to the track…
You lean your seat so far back when you are driving, that everytime you hit a bump, its your back and not your butt that hurts.
You have hydraulics and sixteen switches on a car you claim runs low 10s on the street and corners better than a Porsche.
If you can estimate that your car makes more than 250 HP without ever running it at the track or getting a dyno reading.
You claim that you can get a titanium block for your engine.
If you have ever thought Hyundai and "performance" went hand in hand
If you've ever gone to a parts shop or speed warehouse and asked for a 1" to 6" exhaust adapter...
If you've ever contemplated adding "TYPE-R" stickers to your Sonata…
If you've removed more than 1/2 of the coils from your springs by cutting them yourself ...
If you have more neon lights on your car than a strip club...
You put Kanji on your Ford ZX2, Ford Probe, or Mercury Cougar ...
You own a "TYPE-R" Hyundai or Mazda.
You couldn't afford headlight masking, so you just painted them with flat black Krylon and it's peeling. Badly.
You claim that polishing your intake gave you 5hp.
You own a V-TEC Hyundai or Mazda (especially a V-TEC rotary engined Mazda RX-7)
You have neon INSIDE your car or in your ENGINE compartment
You ever claimed that high gas mileage made your car superior in performance to V8s.
If it takes you 8000rpm to reach 30mph from a dead stop at WOT.
You think yellow plastic interior trim makes your car cool
You spend $500 for a giant hand welded tube for a muffler with the weld marks extremely visible
If you paint your drum brakes to simulate Hi-po calipers
If you install fake hi-po caliper / disc simulators
You have a front wing.
If you lower your car and add ground effects but retain the stock
14inch wheels with disc style wheel covers
If you equate the sound of performance with the sound of a Weed Eater™
If you think bolting a fake muffler to one side to simulate dual exhaust is cool
If you think colored head lights work better
Clear tail lights and turn signals. They’re colored for a REASON!
If you take mom's 4 door Honda accord and do any kind of mod to it
You drive a Ford Escort station wagon with Kanji, wide tires, and Limp Bizkit stickers on the rear hatch
You claim you lost the race because you had a passenger in the car.
You claim how if you went from a roll you would have beat him.
You claim you lost because you missed a shift... and your car is an automatic.
You claim you lost because he must have been on the juice. .
Flying past the person who is 10 car lengths in front of you after they have put on their brakes. . and claim a victory.
after losing you flip your opponent off... rev your motor and fail to break the wheels loose even around a corner.
Tell everyone about how you lost the cop because of your "driving skills".
you are a white kid driving an import. . wear baggy pants/hat turned around, walk with a fake limp and end every sentence with "yew know wha I'm sayin? Relate. "
Your idea of aiming a handgun is raising your arm over your head, pointing the gun away from you, and then just letting your wrist fall to the side to where the gun is almost sideways ...
drive around in a $20,000 import with $10,000 in mods. . and still live with your parents.
You can relate to every line of the song "Pretty Fly For A White Guy" by the Offspring
… And the Number One reason you might be a ricer if... (drum roll)... . you are a skinny, backwards hat wearing, dog chain wallet, 2 ft wide pants leg, Limp Bizkit looking guy with a badly applied peroxide hair color treatment!
You might be a Rice Boy if.......
You've ever made the mistake of lining up and trying to race me with my tailpipe aiming right at your open window. :-laf
You've ever sat in amazement at the 8000 pound truck that just left you like you were sitting on jack stands in a cloud of smoke.
You've ever pulled up to the afore menioned truck and after seeing the door badges, say "Oh, so you have a turbo":-laf
Be it known to all by these presents:
That Gitchesum does not discriminate- he smokes German & other makes, also- not just ricers! :D
That's almost as good as watching Horsepower TV today. I caught the tail-end of an engine swap they did in a Honda. When all was said and done, they made a whopping 180hp on a dyno-jet for the effort. :--)
well, that is 100% more power than stock civics make [they make ±90hp at the wheels]. not that small of a feat. now take a new cummins HO engine and double it's power. 610hp:D :D :D and it'll show lots of interest
Kanji are Chinese characters. They were first imported to Japan in the 5th century via Korea.
Kanji are ideograms, i. e. every character has a meaning and corresponds to a word. In combining characters, more words can be created (e. g. "electricity" in combination with "car" means "train"). There are about 50,000 characters of which 2,000 to 3,000 are needed for the understanding of newspapers.
you might be a rice boy if.......
your dumb enough to pull beside dually with stacks and rev up you little 1" to 5" TIP and think you've impressed me. until i dump it and blow smoke out both straight piped stacks and cover your little "wish i was from the hood but my dads a doctor and my moms a lawyer" budy with BLACK SMOKE and blow you both by a mile with my STOCK truck. :D I took great pride in doing this right in front of the import 'sup em up' shop yesterday. Oo. Oo. Oo. Oo.
Guilty!!
... With 5" stacks, the Maxwell can almost applies to me...
... I HAD Clear BrakeLights (street Legal APC)...
... With a 3,000 Watt Stereo,, I'm over my 950Ft/Lbs of Torque...
... Every truck in my class was running 30+ Lbs of boost...
... My AFE Mega-Cannon had to give me more than 5HP. With a BHAF I dyno'd @ 416 w/o BHAF I dyno'd @ 456. 9 So the Mega-Cannon has to fall somewhere in thos figures,, truck feels TONS faster...
... Yes, I have more than 14 stickers on my truck... .
The Riced Truck,
Merrick Cummings Jr
Well I was going to post a Picture of a Car Craft Magazine that was copied that said Us vs Them: Why Imports Suck! But I can not post the pic big enough for it to be readable. If some one else can i'll e-mail It to you.
Here are a few.
Us: Stickers for contingency
Them: Stickers for Extra HP
Us: Sideways into Third gear
Them: Sideways to avoid high-centering on a speed bump
Us: Throttle Steer
Them: Torgue Steer
Us: 1000 ft-lbs of Torque @ 2,000 RPM
Them: 100 in-lbs of Torque @ 20,000 RPM
There you go. ;)
Here are some from www.ricecop.com
1. You find yourself using the excuse "yo, but you got twice as
many cylindaz" after EVERY race.
2. You have a 4-door 'type-R'.
3. Your gumby pants make it hard to shift.
4. More than 10 of your mods involve shielding what's actually
underneath.
5. You have stickers that even most asians don't get.
6. You have stickers for parts you don't have.
7. You refer to 50hp as the 'big shot'.
8. Your car has so much camber it can drive on its side.
9. When you drive by, WW2 veterans run for shelter.
10. Your exhaust tip diameter is 4 times the inner muffler
diameter.
11. You have 'powered by' anything anywhere on the car.
12. Birds make nests on your spoiler because its taller than the
trees.
13. You sell crack for the image, not the money.
14. You have 'N/T' polished on one side of the car and don't know
what bracket racing is.
15. You will only race if the other guy removes four sparkplugs.
16. You can't race uphills.
17. You have 'All Motor' emblazoned on your rear hatch, right
next to your 14. 50 dial-in
18. You brag about having nitrous and have a 14. 50 dial-in.
19. The exhaust system for your 1. 8L is bigger than most pro-
stock cars.
20. You've spent more money on stickers and stripes than you
did on actual performance mods.
21. You go to a performance shop and go directly to the decal bin.
22. Your tach is bigger than your head.
23. You have a shiftlight and your car is an automatic.
24. You refuse to race because it's a 'show car'.
25. Your only mods are cut factory springs and a 5" exhaust tip.
26. At autocross events you don't compete because you have a
drag-race setup, and at drag races you brag about kicking
butt at the autocross.
27. You have more lights on the front of your car than the USS
Voyager.
28. You brag about a turbo kit that never seems to get installed.
29. Two years ago, your mom used to drive you to school in
what's now your 'race car'.
30. Your bright green $300 air filter is bigger than your engine.
Put this in your 5" stacks and smoke it....
... . nobody seems to complain about all the fine trim at the ricer boy car shows!!?!!
I would never attend one... . but a video/photo-stills highlight show is ALWAYS in order. :cool:
The following has no intentions of starting a war:
For the record... . a car is only a 'ricer' if the loose nut behind the steering wheel is lacking any intellectual capacity. I have driven 600+hp ricers that would make just about any 'Good old boy - American cars are the best... joker' crap their pants.
Matt
For the old folks: "Trim" - a term affectionately given to what you might refer to as "a far-out chick", "groovy gal" or "What a dish!".
Umm... I'm afraid this one applies to me... except for the steering wheel... unless I can count my straight pipe and DD TTPM as REAL engine parts.
And my A-piller gauges all worked for two days before I got around to hooking up the lights.
Oh My GOD!!!!!! If you could get Geno's Garage to sell those T-shirts, they'd make several fortunes!!!!!!!! Or you would... ..... :D
