you might want to check this wire loom, mine had rubbed through
03 so -vs-04.5 ho
Drain water from fuell filter: how often?
on the drivers side - rear of the plastic fake valve cover there is a little metal bracket holding a wire loom
when tighted at the factory the one on the wifes truck was tighted against the plastic cover
right at the small warning sticker about high pressure lines, picture of a hand getting cut in half
it had rubbed through the plastic protective cover, through the electric tape wrap and had exposed a tan wire ... the wire was intact, but her truck only has 13k on it
another 13 would have had a bare wire
Thanks for the heads up. When I was installing my EZ I noticed that too. Mine hasn't rubbed through but the wire loom is smashed in the metal bracket that is holding the harness. I'll try to form the metal bracket so it's not so tight on the harness.
