Engine/Transmission (1998.5 - 2002) You might want to check.
Engine/Transmission (1998.5 - 2002) Gear Vendor Question...
Engine/Transmission (1994 - 1998) transmission not engaging
I was on the way to work last night and got on it 2 blocks from work when I heard a loud pop. I pull into the parking lot and lift the hood to see fluid pouring out of the drivers side onto the ground. I shut the hood and presumed I had blown the head gasket being I run between 45 and 70 psi boost on the stock gasket with it over tourqued. I have been waiting for this to happen then off to O-Ring the head. Well I check again after getting it towed home 50 miles during daylight hours and see fuel spewing out of a injector line at the injection pump. I guess the nut had worked its way loose with the compression type fitting still seated tight enough to hold till that special moment. I found a couple of other lines that I tightened up a bit. I thought I would share with the rest of you.
