You won't believe this.....
Today's Featured Rig
Rude but cool
Check this 6. 0 problem - Ford doesn't think diesel in the oil is a problem till you get over 3 quarts!!!!!!!!!!!! One of the guys says this:
"Diesel is a light lubricant so it is not nearly as bad as having gasoline mixed with your oil. I seriously doubt it will hurt anything during that short running time. "
These folks must have a group buy on 55 gallon drums of Vasoline!
http://forums.thedieselstop.com/ubb...15768&page=0&view=collapsed&sb=5&o=31&fpart=1
Originally posted by Dl5treez
Ford also believes oil consumption is not excessive unless its a quart every 800 miles..... :rolleyes: I'm so glad I don't work with them anymore. :)
I believe that is also the max spec for Cummins engines. I agree its wrong, but warranty won't help you until you are over this and can prove it with documentation. Good thing most Cummins are way under this.
A Johnson
This in the old days with the big rigs would be called "making oil". The main bearings would not last long with the fuel dilution. I suspect things have not changed much in the lubrication factor here.
Chuck Goode
