Okay, my truck is a 2005 with just over 60,000 miles. I have a Kore Recon lift with 35's.
A few months ago, I took my truck to a local shop to get the rear pinion seal replaced because it was leaking. The guy there said there was excessive play in the rear pinion and just replacing the seal obviously wouldn't help as it will just start leaking again. He indicated they would have to tear into the rear end and depending on what they found I could be looking at $1600+. Well, mine is a 2005 with the 7/70 warranty, so I called a dealer who said it would be covered and made an appointment to take it in.
Well, after taking it to the dealer (and it getting hailed on and damaged while there!... but I digress. . ), they said the rear end was "within spec" and replaced the seal under the warranty charging me the $100 deductible.
Well, as the original shop predicted, the leak is back already.
This whole "within spec" thing really makes me mad, as I had the same thing with the ball joints, two dealers said they were "within spec" (didn't deny they were loose) and wouldn't cover them under warranty, yet two independant shops said they wouldn't even pass safety inspection. So, I just changed them to Dynatrac's to be done with it. I've heard my Jeep friends hear the same thing about ball joints "within spec". I seriously think this is just Chrysler's way of getting these things out of warranty.
I'm not hearing any unusual gear noise or anything (although, I have 35" Toyo M/T's, so they could mask it). I don't race or beat on it, but it does tow a camper and also my Jeep around, but that's what they are made for, right??
So, I have several options each with pros and cons:
1) Go back to that dealer and push for a resolution. But, I'm concerned if I raise too much of a fuss with them, they will then start saying it's the lift and/or 35's (even though the back isn't really lifted).
2) Call Chrysler, since this "within spec" is clearly their policy. But, I think all that will do is lodge a compliant against that dealer and it's possible they are just following Chrysler's policy.
3) The guy at the shop I originally took it to has a friend at another dealer, but it's about an 45 min from me. But, I could take it there and have his friend hopefully give an honest assessment. I'm not sure what would come of the $100 deductible I already paid, but that's fairly minor in the big picture.
4) There is a mechanic I trust that works at yet another dealer, but that one is about 90 minutes from me. If it requires multiple trips, that could get really problemmatic getting there and back.
Your thoughts on how to proceed? Anyone else have rear pinion seal/bearing problems? Assuming I have some degree of serious problem in the rear end, I obviously want to get this resolved before my 7/70 ends in less than 10,000 miles.
