BK
I've had a problem with the truck sitting for about 2wks, and not having enough juice in the batteries to start the truck.
Pulled the grounds, put an amp meter in series and found the 0.5mp.
Starting pulling fuses and found that Fuse 12 IOD, of the fuse panel on the left had side of the dash would kill the drain.
Pulled the radio connectors, and CTM/IEM connector, pulled the connector on the glove box light, no change.
I don't have the "high line CTM", so a bunch of things aren't part of the search.
I felt the 0.5amp was just to high, felt is should be 1/10 of that are less.
Thoughts?
Thoughts?
