2nd Gen Non-Engine/Transmission 01 front end redo
Engine/Transmission (1998.5 - 2002) TST question
Engine/Transmission (1998.5 - 2002) best way to set boost elbow
My 01 HO 4x4 has almost 100k on it with the factory set up. What parts would you guys use to make the best front end for the Dodge? I have a mag hytec front cover and Carli front springs. I will be getting a new track bar, ball joints etc. for a complete front end overhaul. I have yet to experience the death wobble, but it is quite loose up there. I just want everybody's opinions for this as I will be doing this in the near future.
be sure to check your end links and track bar bushings, I replaced mine at 170k so it may be a little early for you yet but that really tightened things up and quieted things down, changed the rear sway bar bushings too.
this seems to be a never ending issue with the 2nd gens. There are many ways to go and a lot of different parts/combos you can use, but this is what i have used and seems to have helped a lot:
-Ditched the stock track bar, and went with a 3rd gen conversion/track bar.
-Replaced remaining tie rod end links with new OEM
-Installed DSS steering stabilizer.
The above helped, but its not perfect. Next up for me is a psc steering box and ball joints.
Good luck in curing the never ending 2nd gen front end problems!
Who makes the best ball joints and what is the deal with the psc box? I remember reading a long time ago that someone was altering pump pressure in the stock pump with a ball bearing and spring I think. Helped move the wheels with less effort. Is that the point of the box or not?
