'01 fuel filter chg.
Denny, The R&R of the filter is very easy. On some of the early '01's, the filter top cover has a hex head on top as well as a 1/2 inch square drive hole in the middle. Don't use the square drive hole as it has been reported to break the cover if it is really tight. Just un-do the filter top and remove the filter, change the O-rings and re-install the new filter. I also completely drain the filter housing before installing the new filter to remove any water and debris. I may be wrong, but I don't pre fill the filter housing. My concern is that the fuel that I may be putting in there has not been finely filtered. Chris
