here is the deal, i sold my 01 24v 6 speed a year ago and now have the chance to buy it back, and i would love to but... . i noticed a oil leak at the front of the cylinder head gasket. As it is running i can actually see it pooling up at the edge of the gasket. The truck has 100hp injectors and a edge comp box. I know the new owner has run it hard, but no harder than i would have, i just dont know how close he has watched the egt's... my question is - do these engines normally just require a headgasket change or do the heads often crack? under full load it produces about 37 pounds of boost. are head studs reqired also? On a final note, the current owner installed a south bend clutch and it seems you have to double clutch into sixth or it grinds a little. . is this normal or do the syncronizers need to be repaced? the engine has about 120k on it. . any input would be helpfull, Thanks
