Engine/Transmission (1998.5 - 2002) '02 HO turbo housing???
Engine/Transmission (1994 - 1998) Correct Band Adjustments??
Engine/Transmission (1998.5 - 2002) rear end swaps
From various posts, I have deduced that a FEW variations exist in turbo housings factory-installed on our trucks - since it might be helpful info for later mods, what do I look for on my turbo to determine exactly which size housing *I* have?
Not that it has any bearing on the above, I see my turbo uses a short length of rubber tuming to operate the wastegate - should make addition of my Edge Comp a bit easier... ;) :D
Rubber tubing is a nice thing. Cause when you get your EZ Comp the brass fitting comes out and you put in the supplied brass elbo and viola! 35+ lbs of boost. You lucky dog you. There should be a data plate on the turbo with the model # Have fun. :D
Gary,
You have a 12cm housing HX35W Holset turbo, all the manual engines currently come with this turbo.
Autos come with the little HY35 9cm housing with the hard line.
