Engine/Transmission (1998.5 - 2002) 02 inj. max?
2nd Gen Non-Engine/Transmission Ball Joints
A friend of mine has an 02 with a drag comp and a FASS. He is wanting to put in a set of injectors. He was wondering how large he can go without smoking the head gasket or the charger? Mostly wondering about the head gasket. thanks,
Lance
Depends what he is gonna use it for, I tow a lot, so I went with the Mach 1. 6's from Don. Some guys have gone up to Mach 4's, but then you need more turbo, so I would say Mach 2's would be good. I run almost 40 lbs of boost with the stock gasket, no probelmo:D
Tom
I ran the Jammer 4s with the HX turbo for a few weeks. EGTs were controlable even while towing. You did have to work to keep them down but do-able none the less.
They do smoke an arse load. As much as im suprised to hear myself saying this... . smoke gets old after a while. Just make sure he keeps that in mind.
thanks for all the info. I'll let him make the decision, just wanted to see what was a good area to stop at.
Dlange, If it was mine id definitely go for the mach 7's. lol I'm all about overkill
