TMills said:
I understand the concept just fine. It is MY OPINION that it does not work. I am entitled to my opinion just like your are. It made my death wobble worse and did nothing to tighten up the steering. If the money was spent on a decent steering box, such as PSC, then there would be no need for the DSS. It is just a bandaid for a bigger problem. During some situations it can even put more stress on the bearing and cause it to fail. If this is to hard for you to understand, then you can take it and stick it :-{} .
No offense, but that's just crazy talk!
It does not matter whose steering box you buy. They all have the same basic design. And that design allows for a high degree of leverage on the bearings. The DSS is nothing more than a bearing holder that takes the stress off the boxes shaft.
Now, that being said, the only improvement you would get is if there was some waer on the bottom bearing and it would help things firm up. It is not a fix for an already shot steering box.
Death wobble is usually caused by factors other than the steering box. Typically, it's the track bar, TREs, shocks or just a bad alignment.
I would like to know how the DSS could add stress to the box. As long as the frame stays intact, it's not gonna do a thing.
You sound bitter about buying a product to fix an exisiting issue. I would figure out what was the core cause of the problem and address it. The DSS is a good product. I will have one soon myself. But I don't expect it to clear up sloppy steering, death wobble, clear traffic off the hiway or make coffee in the morning.
You have to undestand the animal you are hunting...
Dave
