2nd Gen Non-Engine/Transmission '02 under dash power
Engine/Transmission (1998.5 - 2002) I will be getting a new lift pump...woo hoo
2nd Gen Non-Engine/Transmission 1997 24v?
I need a power lead on an '02 QC 4x4 diesel that comes on when the ignition is on. It's just to activate a relay, so no need for much aperage. I looked for a wire, but there are so many and I don't have any easy way to tell if there
is power on them or not.
Easiest way for me. was to tap into the fuse block - the fuses are clearly marked - I used the one marked "spare" - it is one that is only on when the ignition is in the "on" position...
Gary - KJ6Q,
Is correct this is about the easiest and best place to get keyed on power. You can use a spade connector to plug into it and run the wire around the fuse block or tap into it from the back. It is pretty crowded in the back.
I think u can tie into the cigarette lighter plug wire. It is a key on supply. I used mine, labeled the wire, & left a wire that would be easy to get to for other add ons.
