.022" DVs
Ebay Programers
AirDog Cummins West
Put a set of these in last night, took out the 181 valve and dropped the . 022" in the 181 seat. Wow, what a difference. Gained 5-6 psi, EGTs are about the same. There is a little bit more haze while driving, but nothing like Full Cuts. Havent been able to tell if the turbo can clean it all as it was dark, and got on it and blew the fitting out of the water/meth controller... Well worth the $$$ IMO. Still grinning from ear to ear about these things!
What do you have done to your afc, and did you have to pull your engine out to install the head studs, also where did you get your traction bars?
You don't have to pull the engine to install the head studs, traction bars are pretty easy to make. IF your gonna buy some check out haisleymachine.com. Last time I checked they had the best bang for the buck on traction bars.
