How can you fix injectors when Bosch will not sell you internal parts,just certain component's are available? I order 200 CVAs from Bosch over a year ago N/A II order over 1k same deal N/A,Remans are no more then harvested part from other failed injectors at this time, T&C will no longer give any type of warranty on Remans other then refund, I have never seen a component that is R/R that has such a high failure rate. If you are able to afford NEW (MAKE SURE they are NEW) you will benefit. Yesterday I received entire CR PUMP. LINES,RAIL,INJECTORS rusted be-on believe, I tried to take pictures but My camera is not able to pick up the rusted parts. Need a better camera.
