I have a 2003 Ram 3500 dually with a 5.9L HO Cummins Turbo Diesel. I'm in the processing of rebuilding my engine, after drooping the 6th cylinder. I getting a new long block with studs, new injectors 100hp, add a new compound turbo, South Bend dual clutch, new Jacob brake, 5" dual exhaust and a Fass 150 fuel system. My original engine had a TST PowerMax CR on it. Can I still use this and/or should I stack with Smarty. BTW, I almost full timing with a 43' foot 5th wheel weighing 15,000 lbs. suggestion/recommendation welcome.
