Thanks John, That's really interesting about the size discrepancy that is provided by Holset/Chrysler and Actual size. Trade secrets? seems ridiculous with something so easily proved otherwise.
All the different single turbos, and my current compound setup produced/produces less cruise boost than the stock (HE341) turbo. I understand why this occurs, no confusion there, how can less cruise boost be better than higher cruise boost? That part baffles me, same throttle position, fuel supplied, etc, let say cruising with a smaller turbo you can cruise with 12/15# boost, upgrade to a slightly larger turbo and cruise boost drops to 0/8# boost (all other situations create higher boost), how does that help anything...less back pressure is all I can assume...
I have actively applied different options with Smarty trying to get my cruise boost higher, less timing helps, in fact running standard Revo vs TNT produces higher boost while cruising. That is why I know you could combine the lower timing of Revo at less throttle, with the higher timing of TNT with more throttle position, using UDC to achieve a quicker throttle response...
I like the cruise boost being higher, it's like the chargers are always "on", throttle response is instant. I used to spin the crap out of the SPS62 I was running, no lag, truck would start easing sideways with almost any additional throttle...dangerous maybe... but fun. So other than mpg efficiency maybe..is there a good reason, or an advantage to having cruise boost lower?
Jess
