My 2003 Northern Lite doesn't fit on my new truck! My last project after the fifth wheel hitch was to install my camper tie downs. As soon as I was done I tried out my camper. It's a close fit in the tail section but it was on my '96 as well. The problem happened as I was lowering the camper. Before the bottom of the camper was on the bed, the overhang was touching the roof of the truck! I guess the 3rd gen cabs are higher. Since it's an '03 camper I thought it should fit a 3rd gen body that came out in '03. No such luck. I contacted the factory and they said I needed to get a two inch thick piece of 4'x8' high density foam (Like Owens Corning pink foam house insulation) and put that in the bed and put the camper on top of it. I have the foam and will be trying it out early next week with a short camping trip. First I ever heard of using foam insulation to raise a camper though. Nice thing is it's very light, the foam must weigh around 5 pounds or less. Anyone ever heard of this method instead of using heavy wood boards? My only concern is it may compress over time but maybe not.
