Archived 03 comon rail, fuel pumps blowing,
Archived Serious HELP needed
Archived can't finish valve adjustment...
Need Help!!! We put a mild street cam in my 03 ram. (nothing else) upon starting the truck, it ran very rough at idle similar to a 12 vlave. within 10 minutes the front seal of the cp3 blew up and dumped fuel in the pan. (never drove the truck, just idleing in the drive way) Thinking it was a bad pump, we put a backup pump on the truck and that one blew within 5 minutes. We pulled the cam and reset the gear in case it was on slightly crooked. Put a new cp3 on the truck and new injectors, started it up and it still ran rough and of course blew the pump in minutes. the truck is throwing a p0088 rail high code. I dont know if this cam is bad and tearing the seal out of the cp3 or if the preasure within the cp3 is blowing it self... .
The truck has a older tst box (no added presure) and a bully dog stack on the economy setting. It has a fass 150 pump that is putting out 22 psi.
I am desparate for any input on what could be causing this, it is my off road race truck and I am entered in the baja 500 at the end of the week... ... .
Please call at any time , 661 713-3443 Thanks Loren
