03 runs without lift pump
Lockers
Fuel filter cap how much PSI will it hold?
I had the lift pump relocation kit from Mopar that moves the lift pump to the fuel tank. It comes with a bracket, banjo bolt, wiring harness, in tank pump, and hose. Once I removed the lift pump from the filter I installed the bracket, banjo bolt, and hose.
Avi
no lift pump
According to an article in TDR, Dodge needs the lift pump to cool the innjectors. Duramax circulates water around them. I am glad to learn it will run without the pump: just in case.
but... you will prematurely kill the injection pump as it is now having to suck fuel from the tank instead of simply sipping it from a pressurized source.
And seeings that the price between the two pumps is a factor of 10+ I'd get a new LP in soon.
My CP3 is now sipping from a pressurized source.
The Walbro is in and I have 16psi post filter (brand new filter). After a half hour of driving I have 15psi post filter. The walbro definetly sucks up everything inside the tank. I am very happy with the kit and the instructions. I definetly recommend it for everyone with a lift pump at the filter.
Avi
I have the FASS and my relay quit working one day and I drove about 15 miles and didn't really notice a difference. (It was pulling fuel thru the pump and filter without being bypassed). I didn't push it though knowing what I know about the VP44 failures. I also read that the CP3 isn't nearly as vunerable to faiulure as the VP44 is.
In reasearching about the CP3 and CR systems I read somewhere that there is no lift pump spec'ed for the european market Cummins applications.
