170K miles on truck. Normal wear parts- 5 sets of tires, one set of front brake pads and shocks and stabilizer.
I'm on my 3rd set of ball joints and 2nd set of u joints front to back and second center/carrier bearing. Second front diff pinion seal. Both front hub assemblies and rotors changed. Power steering pump and gear box blew out around 50K miles, fixed under warranty. On 3rd FCA and second CPS. Replaced injectors around 150K miles. In take lift pump quit around 100K miles, replaced with BD's Flowmax pump, which I just replaced for the 3rd time. I fixed both rear door harnesses, wires cracked. Completely rebuilt both front seat lower cushions, huge improvement. Blend doors have been broke for about 3 years, I have the Heater Treater kit, just too lazy to fix. AC has never worked too good, recharged with no improvement. Replaced transmission with a Goerends around 100K miles, nothing wrong with stock, just had the money. Been running with a malfunctioning tach since 40K miles, doesn't really bother me enough to fix it. Replaced complete exhaust system around 100K miles, rusted thru in several spots. Replaced batteries around 160K miles and 7 years, not too bad.
They may be more, but if so, not much. All in all, truck has been fantastic. This truck gets used pretty hard. The first 90K miles it pulled a gooseneck that ranged between 5K-20K pounds depending on the day. It spends plenty of time in the woods, mostly places it should never go. I've owned this truck since new and am very satisfied with my purchase. I would definitely do it again, in serious hopes of the same outcome!
