If it’s just the Left turn on the trailer I would check fuse 46 (15A). It supplies the power to run the relay and the 12V feed through the relay.
I would expect this relay to "click" on and off as the turn flashed.
Pull the relay, pin 30 should be 12V all the time, pin 85 should be 12v all the time, pin 86 is a Negative signal from the Front Control Module that turns the relay on and off, this pin applies ground to the relay to energize it, pin 87 is positive output from relay to trailer tow harness, 87a is not used. The relay is really a SPDT so when it’s "off" pin 87A is hot, but not used for any wires.
If relay is working correct, check continuity between pin 86 in IPM to LT wire in trailer harness, if it’s open you got a broken wire or connection somewhere.
Here are the electrical drawings Trailer wiring is starts at 8w54-1. Fuses are shown on 8w54-2.
