04.5-05 Juice w/ Attitude Questions
BDPP freezing!!!
48re changes from 03-05??
You are correct #1 setting becomes 40 hp and # 5 setting becomes 180 hp, the juice does not use pressure on the 04. 5/05's on any setting. have mine stacked with an EZ but only use the lowest setting on the EZ and Don't believe I'll ever use the EZ on the highest setting of the juice, just can't imagine it. I haven't had any problem with self control and staying out of #5 setting after trying once I still have a stock clutch,turbo and plastic intercooler. no boost elbow with these electronically controlled wastegates and not needed or recomended. I set mine to defuel at 34 to 36 pounds of boost but have seen 40 (pushing my luck on the little turbo) No sense to push turbo over designed map anyways. I'm not remembering any RMA2000? but did have to sign a form to get the hot version. I bought mine this way never had the standard version just leaped right in. No probelm with questions ask away. yes I feel that were hopefully here to answer each others questions as best we can. best of luck to ya.
RMarkey
This the Juice HP ratings for each level:
Juice/Attitude 20/40/60/80/100
Juice 25/40/80
Hot Juice/Attitude 40/60/80/100/180
Hot Juice 40/60/100
As far as I know version 1. 0 is still the only Juice module version, they did not change the version sticker on mine when it was upgraded to HOT version.
There is a version 1. 1 upgrade for the Attitude module. I would upgrade it.
No boost elbo in the Juice/Attitude kit.
The RMA 2000 number is just to alert Edge that the unit coming back is for HOT program upgrade. Just write RMA 2000 on the outside of the box that you ship the Juice back to Edge in.
Everything upto the 100hp level is not to bad on stock tc/trann/clutch. On 100hp it does have enough extra power to break something if you try.
The 180hp setting probably needs some trans upgrades, air intake, exhaust and maybe even upgraded LP, especially if you stack a pressure box with it.
Well, maybe I'll just wait on the updates for a little and see if I have any problems, hopefully not, and just send everything in later when I need them. Maybe there will be even newer updates ready then.
It' would be nice if they would include cool down timers and other little stuff into these things, it would be the most complete package ever, easy setup too.
