Last Saturday I had a Viper 791XV alarm installed by Best Buy. I actually did a little homework on this and found out these guys were experienced with Cummins Dodge installs.
The alarm is fairly trick with remote start, adjustable wait to start time, turbo timer and some other stuff I'm not sure of yet.
Originally they told me 4-5 hour install, all the connections are soldered and everything tested. I dropped the truck at 10:30am and it wasn't ready until 6:30pm, I was there for the final three hours waiting.
They finally give me the run through of how it works and it's ready to go. As I'm driving away I notice the engine light is on, the little yellow engine outline light. I figure it's 'check engine', so I turn around, go back in and say WTF?
The Sen. Installer tells me this is common. He says they did an install a month earlier that did the same thing, the owner took his truck to the dealer tech. The dealer tech found nothing wrong and the engine light turned off after a week.
He told me it has something to do with the remote start triggering the light and the comp will get used to it and go away.
Well Saturday will be one week, the light is still on, I feel no performance problem but I'm freaked out about this.
I tried to disconnect the Neg batt terminals and turn the ign key to on, hoping this would reset the light, nope. (This used to work on my old D50 pick up).
If the light is still on by Tueday morning I'm calling Best Buy to fix the problem, no matter what they have to do or else;
I'll have Dodge fix it and forward them the bill.
And
If Dodge can't fix it they'll have to return it to factory specs and refund my money, on top of paying the Dodge tech bill.
This sucks because I like the options this alarm has and the adjustability factor but obviously I can't live with a function light beaming in my face.
My question;
Is there any way I can try to reset this light without a scanner?
Should I key the chimes to see if I get a code?
If I should get a scanner anyway, which one should I get that I can probably get locally, NAPA, Pepboys or VatoZone?
Thanks for any advice,
Doug
And
My question;
Doug
