04.5 Lift Pump from Cummins?
relief valve
--Cracked Injector--
I have not had a problem with fuel pressure but I am also thinking of adding a pump just to be on the safe side. I like the filters and setup of the Fass and airdog but think they are fairly expensive. Where is a good place to read up on the Walbro pumps? What model is everyone using on their trucks and where can these kits be purchased?
Thanks, Jeff
glacier diesel products makes the walbro kit for dodge. . Walbro is a company that makes there own pumps. You can do a search for walbro and it will take you to there websight. Glacier has taken one of there pumps and made a kit so it will fit the cummins.
wyosteve said:
Just a quick question to find out if anyone knows whether you can still buy a fuel filter mounted lift pump like the oem from Cummins? I know about the retrofit, but would like to have a spare with me in case the old one dies while I'm pulling the horses/trailer in the wilds of Wyo. If so, a part number would be greatly appreciated as well. Thanks in advance.
I have an 04. 5 and the on canister lift pump is part number 4089602 and costs about $324 from Cummins. I did the same thing... . just carry a spare. Terry
