The safe limit is 567 Lb/ft. By safe it means the limit that will make the trans last at least through the extended warranty period, and most likely as long as an owner could reasonably assume one would last under normal conditions (ie 100,000 to 120,000 miles)
Many exceed this amount, and the trans still holds up, but the bottom line is the more power through it results in more heat and stress, and reduced life.
