The new ebrake is controlled from the engine control computer and does a lot more than simply being turned off and on by a switch. The switch is located on the shifter stalk and has an integral LED to indicate that its on. On cold start up the ebrake can be left on to speed warm up. it will stay on until the engine temp reaches 175 deg and then is automatically turned off. It can be manually turned off and on while driving as desired or simply left on. It will automatically engage after a one - two second delay to alow shifting without activation. Any time you lift off, the ebrake engages after the time delay. Works great in LA traffic by simply feathering the throttle to turn the ebrake off and on. Deceleration is as expected. I can drive down the mountain around the hair pins without using the service brakes. If you are running with the cruise control on, the ebrake is also automatically engaged to hold down hill speed. It has the same warranty as the CTD, plus no possible way to blame the ebrake for any engine problems.
And if thats not enough, the big rig ebrake sound is cool. :-laf
