05 "Idle-Up" Feature - Need a Dodge Dealership Technician's Help
Edge A2
Removing Edge J/A for service
I've got an '05 with a G56 and have been doing a lot of reading on the "idle-up" (fast idle) feature that can be supposedly enabled with DRBlll. This truck has an April 2005 build date. My local 5-Star dealer (who is pretty decent, by the way) has been working with me to try to enable the "idle-up" feature on my rig. I installed the required Cummins clutch switch kit that controls the ground signal to Pin # 22 on the ECM's B-connector, but the technician, service manager and I couldn't locate the "idle-up" feature on any of the screens when DRBlll was hooked up to my rig. My dealer has successfully enabled this feature on a few '06 trucks, but no luck with mine.
Here is the procedure that another member recently published specifically for an '05 (that we tried during my last visit to the dealership):
* Plug in DRBlll
* Turn ignition "ON"
* Enter vehicle information
* Select engine
* Select Miscellaneous (Page 2)
* Enable "high idle" - - - this is what we couldn't find on the screen
* Press "YES" to enable - - - couldn't find this either
We tried this procedure with the clutch pedal switch in both the "ON" and "OFF" postitions.
Is there a Dodge dealership technician amongst our membership who has enabled "idle-up" on an '05 with a G56 and can advise me on the "step by step" procedure with DRBlll? If so, would you please PM me as soon as possible . . . it's been so dog-gone cold here in the mornin' and I would really like to have this feature working.
Thanks!
RJ :confused:
Most likely what you have run into is that the dealers tool does not have the latest programming download. I ran into this with my early '06, they simply didn't have the right program, and like you listed they couldn't even find it. Once the scan tool was updated it only took minutes to make the change. Have them contact STAR, ask for what you need and hopefully it is a simple download, it should be.
I thought only the Automatics had this ability and not the manual. I think read this in one of the forums. I may be mistaken.
I enabled this feature on my 2005 Dodge 48RE auto using my Bullydog Triple Dog Downloader.
Thanks BHolm - - - is there a STAR update number/date for the download that allows enabling of the "idle-up" feature on DRBlll?
RJ
