05 Silencer RIng?
Downloader Question...
Any other 2005's running aftermarket race trannys?
Same ring as on the other stock turbos. just have a stool or something to stand on to reach down to the turbo. Also dont wear your belt-buckle so it doesnt scratch the paint!
Ian
I dont mean to sound like an idiot but is it on the intake side of the turbo? What exactly am I looking for? How does it come out?
Pull that bad boy out and listen to the most beautiful music ever! If you're like me, when you first do it you'll freeze your butt off by having the window cracked just to hear it better going down the road. Beautiful sound! :cool:
Gonna take it out right after work tonight. Trust me the window will be down and I will be freezin! CANT WAIT :D
Once you get it out, Then you have to find a special place to hear it. Mine is a grade about 1000 feet long and about a 6%. There is a building on the passenger side of the road with only a side walk seperating the road from the building. There is also a stop sign at the bottom of the hill. I roll out of that stop sign and then get on the loud pedal and between the MBRP exhaust and missing silencer ring, it is the most awesome sound bouncing back at you off that building... . I think I need some alone time now.....
Take your intake air tube off and you will see a big snap ring and then behind it is the silencer. I used a flat screwdriver to get the snap ring out and then the silencer just fell right out pretty much. Very easy un-install. Good Luck :D
Thanks! I'll check it out. My buddy has an older powersmoke that he's warmed up a bit and I can hear his turbo coming down the road. Sounds much different than any other truck going by. I'm anxious to join the chorus!!!
Thats all you can here on a powerstroke is the turbo? Get a Cummins
Powerstrokes are all right don't get me wrong, I just like Cummins a lot better
I've got a Cummins... He's the one you need to convince.
KClay said:
Oo. Does the 06 dodge have a silencer ring that can be removed in the same manner as the 05?
The only way to find out is to pull your intake air tube off and see if there is a round 1/2 wide ring with a big snap ring holding it in. If there is then yes it is the same. It's the same turbo as on the 05 so my guess is yes it should be the same simple procedure. Give it a shot. :cool:
Another elementry question BUT does removing the silencer ring effect anything else (good or bad) other than allow more turbo noise?
bob ...
Does it hurt anything no, does it help anything no. The only reason that ring is in there is for quieting down the turbo. I see the same boost pressure wether it's in or out. Honestly though I don't 100% know that it wont hurt anything, but the reality is it's just a ring what could be hurt with it missing other that a little more noise? Maybe some one else has proven facts about it, but I think you will get the same answer, it's not going to help you or hurt you. LET HER WHISTLE! :)
