05 Six Speed shifter turning???
2000 RPM Vibration FIX TSB out
Inconsistent Fuel Mileage
Gentlemen
Are any of you 05 56 Honey owners experiencing the shift knob turning on it's own?. Man I can't seem to figure this one out!!. I tried to turn it both clockwise and counterclockwise and without putting a 27" pipewrench I cant move the d** thing what gives?. The 1st-6th plus R pattern has made a full half turn clockwise :confused: :rolleyes:
Mac
Hee hee,
Well it's a feature. After one complete turn you are ready for an oil change.
Seriously though, it is just the small pop-in cap that is turning. I am told
you can pri it out will a small thin bladed screwdriver or such tool.
Then apply your favorite stickem to glue it in place for no more troubles.
Edit:
Just went out and did mine as it was turned about 90 deg. after about
2400 miles. I had better luck using 2 tools, a small thin screwdriver to
start with then the can opener/screwdriver tool on my Victorinox beside
it. It is a little ornery as there is a hatbrim like section about 1/4" below
the top of the insert which must be pried out which is about as ornery
going back in as coming out.
I used black RTV in a few places to hopefully anchor it.
macdaddy said:
Gentlemen
Mac
Same here mine was straight when i left the dealer and by the time i got to home it had done a quater turn clock wise . Now with 800 miles on it is upside down.
Its the decal thats turnin' not the shifter . Its a little annoying but don't look at it eventually it will turn all the way around. ,hopefully? :-laf
As stated above, its the plastic centerpiece that is turning. Pry it out and dab some glue on it... . or use it as an oil-change-o-meter... since they seem to make a revolution every 3-5000 miles!
I just use my palm to rub the thing back in place. If you put a mild amount of pressure with a twisting action, it should move a little at a time.
Alright!!!!!!!!!!!!!!!!!!
Man thats what I like about the TDR, you guys are great!!!!. After reading all these threads on how and when to change the oil the shifter rotation thing make the most sense!! :rolleyes: , who says you have to buy a BMW to have this feature. I have to tell you guys after the 27" pipewrench didn't work I was going for the torch to persuade it. So it looks like a blade screw driver church key,and some superglue are the ticket, thats right up my alley, you know us oil workers when we get our hands on tools :eek:.
As an old timer on TDR, there is a small group of subjects that come up over and over and over and over again. . . this is one of those subjects ;) LOL
Vaughn
Shift knob disc.
I popped my disc out and put some slices in it with a sharp knife. This was on the inside part of the disc that doesn't show. I then put a small drop of silicone on the inside ledge and reinstalled it.
I probably did this close to 2 years ago and it hasn't moved at all. The little slices create traction, like a small snow tire, give the disc grip on the inside of the knob.
Hope this helps. It works! Joe F. (Buffalo)
i popped my disc off too, but then i took a 15mm socket and removed the nut in there, then spun off the handle, and they are both gone [i don't even know where they are anymore] and now sits there a nice #2 billiard ball...
although my #2 ball is stting so the 2 is tilted about 90° CCW :rolleyes:
Don't feel too bad about the spinning symbol, as my '87 F-250/Navijunk had transmission and tc shifters that actually came off in my hand. They were not threaded on, so I had to glue the whole knob on. :eek:
after 60K miles I don't know how many laps mine has done. I just kwit payin attention. Just as long as the shifter doesn't come off in my hand like my Ford Ranger did. . . .
