The "computer control" on the 05 - 06 turbo is just a pwm solenoid valve that bypasses compressed air back into the inlet of the turbo for much, much better spooling. This will work good to about 40 psi, but realize it's not that much more air. The small exhaust wheel and housing, which is the same as the 03-04 turbo, restricts the exhaust to raise intake pressure. If you do nothing with the wire on the valve, the turbo will spool slower than the original. I found that putting a pressure switch connected to the intake (normally closed) with 12 volts to the vlave, will spool the turbo very well. The idea is to give the valve 12 volts up until you reach the setpoint in boost pressure and remove the 12 volts for any boost above your pressure switch setting. 40 is good, 45 is better but you need a fast pressure switch to prevent overspeed, above 50 will leave your turbo in parts. The benefit of this turbo is the larger intake wheel and housing. Nice for an extra 25-75 hp. Not enough for an extra 100 hp.
The 03-04 turbo holds up pretty well to about 30 psi.
