06 3500 6-speed transmission bearings wore out
how long can i putt around on smarty #5?
easy question
06 3500 6-speed 123000 very hard miles..... bearings for 1st 2nd and reverse are bad... wondering about replacing another set of bearings... . they tell me the bearings only come with the counter shaft they are on which is 1200 bucks..... the current bearings seem to be in good shape am trying to determine would it be worth it to change the shaft or run the original one... and what does a new transmission cost and what kinda warranty could I expect with that.
I'd see about getting the guts for the AE if you don't already have it. The G56 AD OD gear is a . 79. and the AE is . 74.
what trucks use the ae with the lower ratio? Looking to buy a G56 for a swapinto my first gen...
Thanks
deo
My '07, 5. 9 was built on dec 18 2006 and it HAS the AE ratio
A neighbor kid has one built in August '06 and it doesn't have the AE ratio.
I would guess that the 6. 7 G56 would have the right ratios.
