Archived 06 4x4 auto won't start
Archived (APPS) Accelerator Pedal Position Sensor Code P0122
Archived erratic engine problem, water damage?
2006 4dr 4x4 auto no power options(windows/locks/keyless)
engine spins but will not crank
can't hear lift pump(no presure at filter) can't find relay any help would be great
Sounds like a dead LP. If you can come across the right fittings, rig up a piece of hose and drop it into a qt bottle of diesel. The CP3 will suck fuel and if that trick works, found the problem. Sucks they designed it to where the CP3 cannot suck through the LP when it dies.
check fuses? when you turn the key on go by the tank and listen. anything? check wiring, maybe it ground out or bad connection.
