Can someone tell me whats going on or is there a tsb out for this what a trip,70,000miles and barfing fluid thanks
Maybe three qts or synchromesh for a 1 qt overfill? Carl's got a good formula.remove the cupholder and the shift stick the red rubber boot will have a split in it across the top. now is the time to change oil. fill the transmission with delvac synthetic SAE50 wt transmission fluid from ww granger or Castrol 50 wt is syngear CD50 o’rileys p/n syn 50-5, next pour two quarts royal purple syncromax through the shift tower while the boot is off. on the dorman i think you need to cut one large ring off before installing, use the smaller width hose clamps
