this is my first post so please be patient with me but i am need of much help and as i understand it this is the place to go. by the way hello all and looking forward to making new friends. To make since of all this i just finished a new engine and add all the goodies to it. my nightmare has been the transmission. I had bd build me a trans the race version, but since i tow they put in high friction plates and used a x converter. the first trans they sent would haul *** but shifted at 2800 rpms. there fix was a new valve body which lowered the shift points but my trans burnt up soon as i went to tow 1800 miles on it total. So they send me a second trans. after install i find that the new second trans has a bad govener presser and transducer. as per request i installed new ones and the code went away. (still hadn't driven it yet) The test drive felt like it was slipping come to find out it is starting in 3rd or second sometimes. well with 2200 miles on her now she is almost gone. the problem now is still the gear starts and she just doesn't know were to shift at or to. 70 mph giver gas and she jumps back and forth from 3rd to 4th a horibble feeling. does the same at take off. when i come to a stop at a light i can't tell if it is staying locked up or just droppen gears but it makes a loud clunk. im in a bad spot and bd just doesn't seem to know what to do they say there sending me another transmission but come on 2 bad in a row what the heck. by the way no one i can find but dodge has a scan tool for 06. No codes on truck at this time. but we would like to see what she is doing. I pressure tested the trans and it has 75 at drive with break on goes up to 120 when locked up and will see it hit 180 when i giver gas and then back to 120. any ideas or similar problems and fixes would be helpful thanks in advance.
