06 edge BETA
Looking for 05 stock boost tubes
stack something with the tst power max 3
Just Installed New Edge With Attitude Monitor In My 06 Ram. I Love It But I Can't Figure Out How To Enter Tire Size Into Computer. The Directions Say That It Should Be In Inches But The Monitor Shows Numbers In The Thousands. I Thought That May Be It Was Showing In Millimeters, So I Entered 4318 (107 Inches). It Saves It But When I Go Back It Shows Me A Negative Reading Of 2311. I Called Edge But They Are Closed On Saturday. If Any Body Has Had This Problem Please Help. Thanks.
it should be with your manual, they also have it on the web site. same as the older models--as they have the same size tire.
The first thing I did was open the manual and my screen does not appear the same as the manuals. The problem is that the monitor numerical range starts at 1700 which if it was centimeters it would be equivalent to having approx. 215 inch tall tires.
I noticed that as well. I have a beta Juice for my 06, but I have stock tires. The manuals online are different than for the 06 (unless they updated them on Friday). My beta didn't even come with a manual, so I had one of their engineers e-mail me a draft (spwlling errors and all). He also mentioned their is an issue with tire size. He said the manual says it in inches, but the attitude really displays it in millimeters. It sounds like upi tried that though.
The other quirk is that the low-boost fueling settings also reset when you cycle the ignition. How do you like their suggestion for "mounting" the box? Or pinching the wires in a grommet?
Otherwise, YEEHAAW!!! :-laf
My transmission is going to hate me... :(
Besides the injector harness plugs and the map sensor what other plugs are there? On the 04. 5-05 they pluged into the Data Link plug but I was told that there was no more DL plug on the 06's? And thats how it got alot of its info on its functions and knew how to fuel?
Map sensor as usual, but it now gets its info from the 16P DLC (data link connector) under the dash. Also, there is a connector near the steering column for the turbo timer.
