Thanks for all your help cerberusiam. So do you think the ecu from my engine will raise the hp/tq? The ecu is the same thing as the ecm, correct? It's located on the lower side of the block? Also at the time of installation I will be putting a 2nd gen exhaust manifold, a he351 turbo, and a pac brake on. Is there anything I should check or change out on the replacement engine before installation, (oil pump, water pump, etc)? O rshould I just do what I have planned so far and just drop it in? Thanks
