Somehow I've run into a problem. I did the easy change out of the 2500 rear wheel cylinders to the 3500 larger ones. No problem. Took the hand held vacuum pump to bleed them, went o. k. Kept the brake fluid up as well. Fired the truck up and here comes the ABS light and the Brake light saying something is amiss! The truck brakes o. k. and seems to roll o. k. , so what happened? I used the trick of rotating the drums and hitting the brakes with the rear end lifted and tires removed, but that seemed to go fine. A clunking noise each time I hit the brakes to break the drums loose, but nothing eventful. Does this do damage to something?
Any ideas?
Any ideas?
