A stock HX35 is efficient to say 34-35 psi. Turn the set screw in the boost elbow out a little at a time (1/2 turn each time) until you get max boost to about that number. The stock headgasket is fine up to the low 40's. After that, it's anybodies guess. My hybrid has been at 44psi for a couple of years now with no issues at all and before that the stock turbo was set to 35psi. If you go back to the stock elbow, watch your EGTs as I bet the needle will be wrapped around the stop pin
