Great website with a whole bunch of information and gurus that are willing to help the less informed like myself. we installed a #12 plate and AFC spring kit a couple of years ago when my son owned the truck.
Recently I upgraded to a #10 plate and 3KGSK.
The plate is slid 1/8" forward from stock, AFC housing all the way forward, and star wheel is about 2 turns from full forward.
After installing the 3KGSK, the initial test drive was a little disappointing. It made good power above 1700rpm but was dead below that and the idle speed did not change. I talked to Mark at Piers and he said to go another click tighter on the governor spring nuts. This raised the idle speed enough that I had to readjust it down to 750rpm and the truck ran much better. EGTs are good and boost went from 26 to 32. The truck pulls very strong above 1700 rpms but is still a little weak below that. If you happen to shift a little early and end up below 1700 rpms, punching the gas results in a very, very slow increase in rpms until you get above 1700 and then it comes on strong. Also, I used to use 1st gear when pulling my boat (6000#) out of the water and up the ramp. Now, if I am not careful, I will stall the motor in 1st. I use Low (granny) gear now and usually have to shift halfway up the ramp.
In your opinion and (to save me some wasted under hood time in this hot and humid Alabama weather) should I adjust the governor springs a click tighter or adjust the governor lever to get fuel at a lower rpm, or something else. Right now the governor lever has never been touched and is in the stock position.
On the #10 plate, should the governor lever contact the plate at the bottom of the plate or at the bottom of the fuel curve cutout?
