Steve St.Laurent
Staff Alumni
Winter finally broke here in Michigan (70 degrees today - was snowing last week) so I finally was able to get around to adjusting my valves since I have 100,000 miles on the truck. Here's what I found - intake valves were from . 012-. 015 (optimum is . 010 - spec is from . 006-. 015) and exhaust valves were . 021-. 024 (optimum is . 020 - spec is from . 015-. 030). I was blown away that they were still within spec after 100,000 miles - and I haven't been exactly easy on the engine
. I set mine slightly tight at . 008 on the intake and . 018 on the exhaust. A note to anyone adjusting theirs - there is a lot of play in the Y from the camshaft to the valves on the 24v engine. I adjusted mine and then cranked the engine over and then rechecked them - it took about 6 times of adjusting them before the numbers were consistent on the next rev (I've adjusted TONS of valvetrains over the years BTW). I continued to adjust them until I was able to get a consistent reading for 2 revolutions after I adjusted them.
