1000.00 Dollars for 4-TOYO 33x12.50x18 Used?
MBRP installed today...freakin' wicked.
Oval Step Bars
Coolslice,
I will sell you the rims and tires, but it will cost you your girlfriend and yes, you have to take her back after two weeks.
Spool,
The tires are nice. Almost 14" wide and they do make noise! I read it was a A/T but not true it's a M/T. E rated at over 3500lb each. The 33 inch Toyos above were E rated but only 2980lb.
Coolslice said:
According to Toyo's website those tires are only rated to 2910 lbs. That seems low for an E rated tire based on what I have seen. It that too low???
I currently run the 295/70/17 Nittos. A "D" load rating good for up to 3415 lbs, yet one of the tires disintegrated on me last week and I only had a 400lb ATV in the back. Fortunately it was one of the back tires, otherwise I'd probably be dead if a front tire. The nearest tire store didn't have anything that would match exactly so sold me a Bridgestone 285 KO to get me home. Not taking any changes and going to have all tires changed out to an "E" rated tire. The only problem is there are so few option currently for E rated tires.
