Originally posted by Don M
Bob,
Increasing pop pressure will close the window even more.
Higher pop pressure will make the injector open later and close faster, if you are speaking of injector pop off pressure.
Maybe you mean injection pressure, like from the pump itself?
The window I gave in milliseconds is for roughly 30 degrees of crank rotation.
The HP limits are not reached yet. There is still more power on the table, I still have yet to find it though
Don~
What you run into is that the pump cannot make infinite pressure. Diesel is compressible, and the pump is only good for just so much, and after you reach a given point, the pump just tends to leak more and the pressures don't really climb much.
If memory serves, the P7100 is good for some 20,000 psi or at least in that neighborhood. If that's all you can generate, then 20K PSI will flow ONLY so much fuel through a given injector. As you speed up, the time the pump is pumping gets less and less, and so too, the amount of fuel you can flow through the injector at the maximum pressure you can generate will fall.
More holes, bigger holes (only works to a point, then the fuel just dumps out the tailpipe), will get you more fuel flow.
The VE pump on the 1st gen trucks has a larger plunger than the P7100 does. Theoretically, it can pump more fuel than the P7100 can... But it lacks the ability to generate the pressures needed to flow big amounts of fuel, which is why you see relatively low horsepower limits on VE equipped engines. Those who crank the VE way up with the fuel screw just inject fuel for longer and longer durations, which means a lot of fuel at the end of the injection is too late to make power... and just smokes. This is what's happening again, just at a higher power level, with the P7100.
If you're REALLY determined, custom build a cylinder head and pistons with 2 injectors, 2 injection pumps, and c ustom built injectors. You could make more horsepower without smoke (in theory) than you can can now doing that, but the engineering involved would be a daunting task... something that would strain the abilities of Bosch, Cummins, and MIT all put together.
The VP44 is supposed to be able to make more injection pressure than the P7100, I believe, so theoretically, one would be better off starting with IT not converting... . So how's that for a connundrum?
