I can respect that. I'm waiting on a derringer tuner from them for the Rams, if that ever comes out.
I have 19.5k on the truck now and you guys are making me worried. Looks like I'll be doing it sooner than I thought lol
Unfortunately I bought my truck used with 15k on it. The honda dealership that had it didn't give me a manual or anything else. I only got one key fob as welll.. long story...Read your manual. Knowing what I know that CHITZ should have been outta there 15k back.
You want to get that “Break In Lube” out between 10-15,000 miles. All that extra metal from the gear set working in and becoming friendly with each other is not good for the long ride. That first time you remove the cover you are going to think someone mixed in some NeverSieze with the lube. I had to use a rag and some Brake cleaner to wipe out the inside of the rear housing. Each lube change after you should see less an less stuff inside the rear. Unless you have something failing. I would bet that bearings in the rear end shown in this thread with 800,000 km on it are toast. No way can you have that much metal in there and not take out the rollers an races. Just like a stern drive or an outboard lower unit. Once you start making that fine metal like that things go south in a bad way fast.Unfortunately I bought my truck used with 15k on it. The honda dealership that had it didn't give me a manual or anything else. I only got one key fob as welll.. long story...
Isn't it bad to use brake parts cleaner to clean out a rear end?
Using brake cleaner removes all the oil if you don’t get oil back on the parts rust can start really fast in humid conditions. The nice thing with the Brake cleaner is it evaporates leaving nothing behind.
Dean red truck! How are things up there ? Still happy with water treatment co?
We still have a First’s position open down here at the Cape. We need a Good Engineer.
