The 10 is far stronger than the 11 up to about 2400 rpm. From 2400 up (assuming stock governor springs for these rpm's), it is about 20 hp stronger than the 11, if I recall the dyno sheets correctly. It is hard to understand the difference from just the peak power numbers. The 10 actually gives peak hp at lower rpm, about 2000 giving 345 on the dyno, and then begins cutting back fuel to keep egts down. the 11 is more of a street plate, with more torque control, in the range of 680-720 ft lb depending on the rest of the setup like turbo housing. The 11 is designed not to roast the clutch if it is in good condition. The 860 dynoed ft lb of the 10 necessitates a better clutch. Moving the 11 forward can give it more high rpm power than the 10 in stock position. Moving the 10 forward an equal amount will allow it to keep its hp advantage over the 11 at all rpm. However, I found that . 035" forward of stock gave the 10 about 373 hp (add 12 hp if using Torco 75-140 instad of stock lube; add 10 to the 345) but egts went up around 150 degrees. So, plate position bejcomes pretty important if you want to watch those egts. The 10 can easily give 1500 deg or more at 2000 if you are pulling such a load that it stays in that rpm range for long at full pedal. Mostly you accelerate out of it so fast that your pyro probe doesn't have time to read the high temp you got for an instant. By the time the probe catches up with reality, you are at higher rpm and the fueling pullback might be enough that you feel nothing really bad happened.
A while ago I tested the 191 delivery valves. On the flow bench they gave an increase at idle, from 30 to 43 cc/1000 strokes. At full flow, nothing (but we will retest with a bench setup that can take over 600 cc/1000 strokes to be sure). On the dyno, it was a warm day and the engine was pretty much air starved in the configuration I was using then. The first run with 191s seemed 15 hp stornger. Backup run was 15 hp worse than the 181s or down 30 hp total. Go figure. However on the street, I couldn't get rid of the smoke trail even on gentle takeoff with big injectors, so the valet switch wasn't able to fix the potential smog nazi problem. I went back to the 181s and used them for the 609 and 613 hp runs.
If you want more free dyno data, you will have to wait until I get around to testing the stuff you are interested in. I have several projects going on with Lawrence; his shop and dyno get busy at times (poor guy has to run a business sometimes). It is too expensive to go to another shop and pay $50 for each two runs; no one is helping me pay for parts etc. to get the information I am giving away here. I wish others would do some of the testing and share their information like I have done.
