12 valve 6 speeds??
Finger Bomb!
A dealer told me that DC had a 6sp for a short time in 1/98 but it had bugs and it was discontinued for awhile. Did they get the bugs out on time to get the 6 sp. in any 12 valve trucks? Craig
97 3/4Ton, 2WD, 5SP, #11 Plate, 14 Housing, AF942M Air filter, Gutted Cat, 4"From Turbo, Airlift, Shortened Frame, Custom Bed, HEY FORDBOY POWERSTROKE THIS!
Not that I heard of either but in theory shouldn't it bolt up???
'94, 2500, 4X4, SLT, 3. 54 gears, Prime Loc, Silencer ring in the tool box, DeeZee bright tread running boards, side box boards and mud flaps. Alpine CD player. I cleared 100K mi while the board was down. Jardine Performance 4" exhaust (sounds just like a Pete, it's great) :)
I know of one 98 12V owner in Portland OR that has retrofitted a 6 speed into his truck. It cost about $5000 I recall. I have the details somewhere if anyone's interested.
1997 4x4 CC 5spd, CPL1553 engine, Horton fan, Sport headlamps, Optima RedTops, 98 shift levers and console... looking for a NV5600.
I heard from a guy i used to work with, who owned a garage, that the NV5600HD is nothing more than an add on to the 4500. He told me that the nv4500 could be converted; that there is a "kit"
Is this BS? has anyone else heard that?
joe
1990 w-250 4x4 cummins 5. 9,NV4500,tweaked injection pump, 16cm2 housing, 3"
JRE exhaust, 4. 10 gears
Why worry about a 6 speed? Install a gear splitter ($1800 at Camping World) and you've got a 10 speed. Anyway, from what I understand the 6 speeds have problems all their own. As far as performance, the 12v's are far superior to the 24v's and the NV4500 with a splitter is far superior to ANY 6 speed. Upgrade what you've got.
'94 SLT 2WD, 5 Spd. , TST #6(250/635), 215 HP Injectors, Calibrated Pump, 14. 5 cm2 Turbo, ATS Exhaust Manifold, 3. 54, all Synthetics, By-Pass Filtration, EGT & Boost Gauges, Psychotty Air System, 4 " exhaust, BD Exhaust Brake, Horton Fan, Prime-Loc, Cummins Chrome Kit, Homeless Cat, Air Lifts, Rancho RS9000's, PIAA's, 255x85Rx16's and copious amounts of 12v Pride.
Joe, that guy was b. s. ing you about it being a add on. It is a totally different transmission (I think I read it weighs 160lbs. more than the 5 speed). There was a thread (I think from Fritzs' web page) that had pictures and specs on the 6 speed. I know a engineer that had one of the first 3500 6 speeds to drive and write a evaluation on. This was before they were ever in production. The truck was a 24 valve- I don't think they ever had one behind a 12 valve engine.
'98 4x4 12V QCab Auto (ready to BOMB)
IF--------------
You have a unit (truck) that has a speedo sensor in the rear axle instead of the transmission-all you need is the 6 spd-shifter lever-brackets as the bellhousing is part of the 6 spd transmission, and the transmission,don't remember what the mfg. told me about the drive shaft ,to long???
If the pick-up sensor is in the transmission forget it. I did, and the transmission would have been free(for testing ).
