I am in the process of putting a 12 valve Cummins into a 2003 F350. I would like to put an air compressor in place of the vacuum pump so I have air in the field and for the air bags without having a gas compressor in the box. I don't want to put the vacuum pump back on the motor because I won't need it and they just eventually start leaking oil. I looked at an FL70 Freightliner with a 12 valve in it and that compressor, a cummins factory installed part, will bolt to the motor but there are 2 clearance issues. It will hit the 2 brackets on the side of the p pump and with the truck power steering pump behind it it hits the motor mount. I have searched the internet but can't find much for different options for compressors. I hoped someone here would be more knowledgeable then I am and would have an idea on what compressor would fit. I would prefer one that goes where the vacuum pump does but wouldn't be against a belt drive one if there was a way to get rid of the vacuum pump but still run the power steering pump. Any advice or pointers would be greatly appreciated.
